How do I adjust a farmall h carb
marlin54
Took my carb apart to clean it and needle was sticking and need to get it adjusted close enough to start it. It's a Ihc carb and not another brand .it's not a super either. Serial number is like 210 k . On the carb I see the numbers 212 casting. I think if I remember some of the screws on Ihc carbs have to be turned out to lean and some are in to lean . Any help would be appreciated
If it was running before, and all you did was un-stick the needle valve, then no adjustments should be needed. However, here are the factory initial settings.
High speed idle (load screw) is 3 turns out from being seated.
Low speed idle is 1 1/2 turns out.
ALL H carburetors are the same.
Here's my procedure;
Make sure the float isn?t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so the float doesn?t rub or touch. Pretty important.
Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber.
[Note a new float might already be set correctly.]
INITIAL settings are as follows to get the engine started;
Main fuel adjusting screw; big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture. [This screw adjusts fuel.]
Idle-air-mixture screw; smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner. [This screw adjusts air.]
Idle speed screw; faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages in the slot. [This screw adjusts RPM?s.]
FINAL settings are as follows;
Get the engine warmed up, and idling.
Turn OUT the small idle-air-mixture screw until rough running, then turn in until engine idles smooth. (Mine is set at 1 turn open.)
Rev it up, wide open, warmed up, then turn the big main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. (Mine is set at 1 turn open. Other advice has been to set it at 2 1/2 turns open for pulling implements.)
Engine should rev up smoothly and evenly.
Too Lean = stumble, sputter, damaged melted plugs.
Correct = tan plugs.
Too Rich = back smoke, black sooty plugs.
