I think I got the wiring straightened out on the IH 424 gas tractor FINALLY! All I have left to do is replace the light switch (old terminals are corroded and not allowing current to pass), and get the 12 volt generator to charge.
I have ran the troubleshooting guide that you guys frequently share and here are my results. I have verified the wiring is correct, so I am at a loss here. I can double check my wiring but looks like everything checks out. I did not check the ground at the generator, but with the last test allowing the light to go off, you would think it wouldn't be the ground. What do you guys think??
