TractorLinks.com
Show Parts for Model:
Farmall m factory wide front
FarmallMN
12-06-2017 07:13:37
Hello, I'm new here. I have a farmall m with factory wide front. My question Is is there supposed to be a bushing where the tie rod connects to the plate on the steering bolster? Thanks even if you can't help.
FarmallMN
12-07-2017 06:52:39
 Re: Farmall m factory wide front in reply to FarmallMN, 12-06-2017 07:13:37
Here's a attemp to upload a picture.
DeltaRed
12-07-2017 09:15:22
 Re: Farmall m factory wide front in reply to FarmallMN, 12-07-2017 06:52:39
No 'bushing'. What you see is normal wear from almost 70 years of use.These days,they all look like that. If it bothers you,take it to a machine shop and have them bore and build up and sleeve it all. and spend a large amount of money.
rustyfarmall
12-07-2017 06:28:30
I will assume that the tierods are the style with the clevis ends, and attach with a pin through a hole. Due to age and normal wear and tear over the course of 60 to 80 years, those pins will be worn, and the holes are probably egg shaped. New pins will take care of part of the sloppiness, but the holes may need to be drilled out and some sort of bushing installed. Bushings can be made from whatever.
FarmallMN
12-07-2017 07:08:18
 Re: Farmall m factory wide front in reply to rustyfarmall, 12-07-2017 06:28:30
How could I exactly do that?
SadFarmall
12-06-2017 23:38:50
This might be of help?
SadFarmall
DeltaRed
12-06-2017 18:25:57
There are several Wf that will fit an M.But I don't recall ever seeing a 'bushing' in the place you describe.Maybe a picture,or more info will help us help you
FarmallMN
12-06-2017 20:43:44
 Re: Farmall m factory wide front in reply to DeltaRed, 12-06-2017 18:25:57
Sorry I can't post a picture as I recently joined. Could I email you a picture? Sorry I'm new to tractors and this fourm.
