Clutch problems
I have a 674 international with the high and low 4 speed transmission, so I guess it's really a 8 speed! My question is that when I let my tractor sit overnight when I get on it I have to go from forward to reverse several times before the clutch will release and start pulling, but after it starts pulling it is fine. Any suggestions would be greatly appreciated
Hi, does you 674 have a T/A? Lever like the throttle lever but on left side of dash?
Is the clutch adjustment proper, about 3/4" free travel?
Does it do same thing if it is left in 1 Low, FWD or REV?
JimB
When was the last time the throw out bearing was greased ? There is a plate on the bottom of the clutch section there should be a grease fitting for the throw out bearing in there on the bottom of the bearing.
Look at Casih.com 574 clutch controls picture and number 7 is your grease fitting.
Found the grease fitting for the throw out bearing, actually went ahead and greased the whole tractor, it actually did seem to help a little but it's still not pulling till u go from "low range" forward and reverse, I counted today it took 22 times for it to actually engage and start pulling hard like it should, I had a five foot box blade behind it today and it pulled it fine all day after I rocked it back and fourth this morning
