Farmall super m and Farmall 300 compatible parts?
Hi all, I have a Farmall super m that I just pulled into my shop to restore. A few months ago I bought a Farmall 300 with hydraulics and a wide front end. I did some measuring and it looks like the wide front end on the 300 will fit onto the super m which has the stock narrow front end. But I was wondering if anyone knows if the distributor mounted live hydraulic pump that's on the 300 will fit the super m? Just trying to get more hydraulics onto the super m without all the cost.
Pump won't work. If a IH wide front on the 300 the steering arm and frame saddle keeps it from bolting on without modifications or finding the right parts. Hubs, spindles and wheel bearings are lighter than your M narrow front if original 300 front. Other type wide fronts may adapt or need different things.
There are only few parts that will interchange between a Super M and a 300 - generator, gages, steering wheel, etc.
So I just went out to check for a model on the 300s wide front. No numbers or plates to identify it. But it doesn't look like a wide front End ive seen online and I can't seem to find a picture of one that's like it. The big difference I see is that it doesn't have the saddle that mounts to the frame rales on the tractor. It only bolts into the 4 holes under the steering colum, and unlike all the ones that I've seen that are only 4 holes on the block of the wide front that are spaced apart with no way to drill different holes because they're in the casting. This block has a solid piece of steel that the holes are drilled into(see pictures) Also the pivot point that's usually bolted to the frame rales with a saddle is actually apart of the front end that bolts under the steering Colum. The first picture of the wide front off of a tractor is a regular style wide front for a 300 for comparison. The picture of the two bolts shows how my wide front bolts to the tractor. And the other picture shows how there's no saddle
