Hi All... I am knew at owning a Farmall H 1942. I would like to hear from you folks
that have many more years of experience with the H series Tractors than I ever will.
I would like to change the Oil in the rear end of the H just below the PTO only because
I think it needs it, and I have know Idea if it has ever been changed. So to start out
knowing when these fluids have been changed I would like to change it.
I see the drain plug under the PTO. I don't know how many gallons I should put in or what type of oil.
I have two Manuals that I purchased for this Farmall H the TC-27E and the Operators Manual Farmall H and HV
Tractors. Can some one point me in the right direction for the proper Manual on what type of oil goes into
the rear end of the Tractor?? Thank you for your reply...Ron (Maine)
