560 bad front end
No a 706 and a 560 top steering block will not interchange. A 560 has a steering shaft going to it and a 706 is completely hydraulic.
Behind the steering shaft where the 4 bolts hold it on the cast front one bolt holes is pulled out cracking the casting where the last oring goes brased it still didn't hold. Getting good at taking it apart from running tractor to all done 1 hour. Shop time probably 3 ha thanks I think going to try junk yard thanks
