464 hydraulic fluid plugs
Hi, yes there are 3 drain plugs 2 on the bottom and 1 by bottom of right rear axle. The one by the axle maybe used for a return line from a FEL hydraulic control valves. There is speed transmission, range transmission and differential.
Re, Hydraulic Fluid, use IH Hytran or equivalent.
JimB
