5130 shift module
sandel
Neighbor has a CaseIH 5130 with transmission issues. Determined need to replace Power Shift Control Module- p/n 87721353. Local dealer says that part is not available. Hard to believe they don't exist somewhere. Suggestions or options? Thanks.
not sure if its the same but look up 5230 they may have updated. had work done to mine this past spring. otherwise not sure if it would be something you can get from A&I.
Case had re-mans available part number 87721353R. Shows no re-mans available order new at this time. Send it out for repair to Global Electronic Services.
Phone number 877-249-1701
