806 Hydraulic lever
Looking for information on an 806 hydraulic control linkage. I have two levers by the seat. The outside lever has too much free movement on the outside lever. Question is: where the shaft hooks up to the valve linkage on the shaft looks like just a small roll pin hole. Is that all there is to link the shaft to the valve rod or is there a half moon key in there and the roll pin just locates the shaft to the linkage.
Appreciate the help as always,
Bob
The roll pin is all there is. Darn poor patent but it is what it is. You can drill it out and install a larger pin but only slightly larger.
Thanks a lot for the information and help. It doesn't seem like a lot to hold that, but I'd be the first to admit that when something works fine for that long it must be OK.
I just wanted to get an idea about the fix before I took it apart.
Appreciate it, Bob
