Al L. in Wisc.
The 340 has been converted to 12 volts and I am replacing gauges.
*The key switch has off-on and the third position won't allow the tractor to start but will drain the battery if left in this position, I found out. Fellow who wired it said he could have used the two position switch off-on; correct? Current contacts: one to alternator, one to starter button and one to front contact of resistor: see photo above. In the photo, the resistor rear contact has a wire going to the coil and another wire from here goes to ??? as I didn't label it.
New gauges include light, amp and oil. I would appreciate help in getting this wired correctly. Thank you
