Farmall 460 hydraulics
vinnivee
I have a Farmall 460 and the rear fast hitch wont work....I cleaned the hyd filter and with the filter out I started the engine briely and hyd fluid came gushing out. The power steering works ok but none of the other hydraulics seem to work. I checked the fluid level it is good. Does anyone have an idea of what to look at next?
Vince
my 460 had similar issues and I think I had a problem with the Hydro controls that are up on the right side and tried to take it apart with no luck ,,,so I believe I bypassed the controls and added a new standard 2 spool valve, one for my loader and one for the rear hitch. does any one have instruction and a blowup view of those original valves they put on the 460's as Im looking at another 460 that has the same problem and thinking its those junk valve pack they used . I think its called Hydro or something . either way I wish I had an exploded view of how it works.
I was thinking about that relief valve because there is no pressure to any of the outlets or cylinder....where is that relief valve located?
First off you can find a parts diagram on most any case/ih website, second, dig through the archives on this site you'll find similar problems and solutions, good luck.
