Previous owner says he swapped out the original motor and replaced it with a yellow colored farmall motor and he rebuilt the
injector pump , and and also cleaned the injectors . So when starting cold it has ALOT of smoke untill it gets warmed up.then
its not bad. I don't know where to start with this tractor...never really worked on diesels and can't find a gas motor to
replace it . could the pump not be built properly rebuilt? Whats the possibilities
