John M
- Location
- Nunyafn business
Been having an issue with my starter/genny on my 154 for years, so I decided it was time to figure it out. Turns over fine cold. When it gets hot, as in running for say 2 hours or more, if I shut it off, or bog it down by accident, it will turn over, but it acts the battery is bad. If I let it cool off, it will spin right over again. I do my best to not bog it down, and have gotten pretty good at lifting the deck and knocking off the pto at the same time. So far, I have replaced the cables with bigger ones, I think it was 0 gauge, but I cant swear to that but they are bigger than the originals. Have had 2 new batteries in it since I got it. The solenoid was replaced, and the starter/genny was gone through and reinstalled Saturday. It has a newer Prstolite distributor, btu that was installed when I got it, and I have it set dead on, but it may not be the right one for the 154, as the tag has broken off. I installed a Zenith carb due to the IH carb top being warped beyond repair, and the dealer had this one in stock. The engine was rebuilt when I got it. After running it for close to 3 hours yesterday, I shut it off after letting it idle for 15 - 20 minutes to cool off some, attempted to restart immediately after shutting it off and the starter just dragged as before. I hope I have included anything relevant to help figure this out finally, if not ask. Any ideas whats going on?
