TractorLinks.com
Show Parts for Model:
Re: F-12 Transmission ???????
Janicholson
11-14-2017 16:47:33
There is about 50% of the volume of the housing that is air. When the temperature changes from day to night, ans seasonally, that air expands and contracts quite a lot. (maybe 2 Quarts of air with 25 degrees change in temp. As it cools, it sucks in air to fill that volume. as it does, it drags in moisture which condenses on the cold metal and contaminates the oil. In the past when these tractors were tillage and daily workers, the oil was heated from friction and viscous shear to warm to hot levels. This drives out the water. What can be done is to heat the trans periodically to mimic the work. or drain and heat the oil in separate containers (safely). Jim
