Carb SLOWLY loads up. when it is full it drips or runs out on the ground depending on how much I have the gas turned on at the bowl,. When started, it will blow black smoke for a minute or two, then clear out and run for say 5 minutes or so then shut down. Wait for an hour for the bowl to fill and do it again.
Ive had it to a mechanic 4 times, and hes been out here 2 times for both the B and my 48 H carb troubles. Im losing faith in him by now. He takes the B carb, and I pick it up the next day, and its no better. As to the H, He says he can fill the hole, then tap it out, and make a screw for the idle adjustment. Im trying to find which is cheaper, him doing that, or me finding another top for the H carb.
Hes also got my 50 Cub carb. I havnt heard anything about it. Ive paid $50 so far on the H carb minus the kit, and $30 on the B minus the kit.
