Needing a top for a carb for an 48 H
Farmallb
Mine, the speed adjustment needle blowed out from it and the hole looks oblong. Mechanic thinks that it had had trouble before. What can I expect to pay for a used but good one?
I had the same issue on mine. We drilled the original hole out and threaded it for a new bolt that was large enough to take the original screw. I then drilled and tapped the larger bolt to accept the original speed screw. I jb welded the larger bolt into the carb body and made sure it was flush inside and outside of the carb. The JB weld set up quickly and I put the new speed screw and spring in the new hole and it was good as new. Or you can get a new to for about 25 to 30 bucks and save the time!
