TractorLinks.com
Show Parts for Model:
Nebraska kirk and other F30 folks
wilson ind
11-14-2017 11:38:55
Got my F30 loose. Need an exhaust and possibly intake manifold. Depending on how the separation of the two goes. Any body have a good used exhaust manifold and or any reports on quality of rosewood reproduction parts ? Also clutch is stuck. Cannot seem to get the spyder bolts out of the clutch to transmission coupler. Whats the secret? Are the bolts a press fit, threaded or just plain stuck?
Nebraska Kirk
11-15-2017 15:51:12
 Re: Nebraska kirk and other F30 folks in reply to wilson ind, 11-14-2017 11:38:55
I do not think Rosewood offers an intake/exhaust manifold for the F30.
YT sells new manifolds,
http://www.yesterdaystractors.com/Farmall-F30_Manifold_R0304.html
Other sources sell the same manifold too, shop around for the best deal.
wilson ind
11-15-2017 15:55:13
 Re: Nebraska kirk and other F30 folks in reply to Nebraska Kirk, 11-15-2017 15:51:12
Thank you had no idea YT had them
Nebraska Kirk
11-15-2017 15:44:46
Steiner has new ones.
https://www.external_link/IHS139-manifold-w-adaptor
Or this one
https://www.ebay.com/itm/MANIFOLD-IH-FARMALL-F30-W30/300278769703?hash=item45ea026827:g:EH8AAOSwdGFYzTDN
James Williams
11-15-2017 05:25:24
I just replaced a F30 manifold that came from steiners and the quality was terrible.
Chris NW Ind
11-15-2017 04:27:22
If they are the same as my F12 and F20, just reassemble all the nuts loosely to keep it all together and then jam up the drive shaft with a bar against the frame. As somebody said, the bolts are a tight fit (not threaded) in the cast couplers. I think I used a good wrench or 2 and popped them loose.
Chris B.
robgIN
11-14-2017 17:18:05
those bolts are a taper fit into the coupler, I have gotten mine loose with wrenches or a 3/4" ratchet and socket if it is accessible, take nuts loose and tap on bolts to try to knock them back, just be careful not to mushroom the threaded end. Or putting the wrench on the bolt heads and smacking the wrench with the hammer will sometimes pop them loose. Heat and penetrating oil never hurts , patience so you don't destroy things. Usually a combination of all of the above will get them out.
Leroy
11-14-2017 16:44:44
I just saw the name, you asked me to email you on the hay rake and I sent you my email twice, did you finally get it?
wilson ind
11-15-2017 03:10:33
 Re: Nebraska kirk and other F30 folks in reply to Leroy, 11-14-2017 16:44:44
no
Leroy
11-15-2017 06:24:35
 Re: Nebraska kirk and other F30 folks in reply to wilson ind, 11-15-2017 03:10:33
There has to be some reason your computor is blocking yt. Can you send me an email using yt mail system and my email is open on here I know in classic.
wilson ind
11-15-2017 14:25:44
 Re: Nebraska kirk and other F30 folks in reply to Leroy, 11-15-2017 06:24:35
Just send normally to bills4030@hotmail.com or call 812 699 0011
Leroy
11-14-2017 16:42:14
Dwane Helman that started Rosewood machine is a Personle friend of mine and his kids are running the place now. Rosewood is the name of the town the machine shop is in and Dwane is a big Fordson man with hundreds of the old Fordsons.
16-30 oilpull
11-14-2017 14:52:56
Rosewood has quality products
