ou intended to stomp on his toes and did.(quoted from post at 06:56:43 11/14/17) didnt think i was a total dick about it, just try and give the correct facts without too long of a story is all. many here just give a response without any reasoning behind themselves. didnt think i was graded on creative writing. and i did reread it and dont know what you are refering to as being abrasive. all i did was throw a joke in at the end saying it was an ih not a hopeless case, meaning it will run. i think posters should be more clear on their explanations would save a lot of assuming here and be a lot easier to get to the actual problem. so have a great day everybody.
(quoted from post at 18:04:59 11/14/17) It was just Aaaumed that I put dirty fuel in the filters on the 1086, wrong, I have a filter system on my supply tank that is better than the new filters put on the tractor. You know what happens when you "ASSUME". All I wanted was some thoughts and ideas as to why a machine that was running fine when shut down would no longer "fire" or "crank" when the same procedure that worked for 30+ years was followed. I wind up getting a degree in mech. engineering. Really, thanks to all of you!
