urbancase
this is the pic of the 1586 I picked up this summer got it at auction for 2800.00 wasn't looking for one but wasn't going to let her be parted out. it was sold saying it was running in the field and the farmer heard a loud pop and stopped moving. and now looking what it needs to fix. has a good reman motor in it but has fuel leak from return line form what it looks like. took top link cover off and the ring and pinion are turning but neither tire moves so I saying right now final drive and it is planetary drive set up. looks like some grinded metal shaving on edge of case in back. the shifter will go in all 3 gears, pto works and can get shifter to go in reverse but will not go in park. what do you guys think do I have 2 different problems? or is it the same problem with final drive. or am I missing something? also going to switch the pto from 1000 to a 5401000 pto and drain the back out and wash with solvent to get it good and clean.
anybody that's dealt with this feel free to comment as never been in the rear end of this size tractor. also plan on paint job and getting bugs out a electric system, cab kit and ac working.
thanks guys
thanks guys
