indianabuckman
Went to move the 856 and when I tried to start it, the starter hit once put did not turn over the engine then after that nothing happen, I had lights the oil pressure tellite and alternator-generator tellite was on but the tractor was dead I tried it several times but would not turn over. Went to the house and got my mm and jumping cables check the batteries and had 6.5 volts. Hook the cables up to jump it with the truck. Push the starter button once nothing then push it the second time and it starts right up. Any ideals what I should look for? safety starting switch, solenoid, loose wire to any of those or maybe batteries the connection at the batteries were tight? Shouldn't I have 12 volts at the solenoid?
