Pete, I've been going over this stupid Behlen setup over and over, and just can't figure out how the roll pins go in these V shaped notches. I looked up the roll pins on the CaseIH site, and I have all the correct length roll pins. I painted the sections different colors to make them stand out better, I'll clean that off once I figure out what I'm doing. In the picture that has just the shaft in it, is the roll pin supposed to pin both inner and outer pieces of the V? Or is it supposed to just lock the inner piece in place? Then on the other picture with the shaft and the collar, is the roll pin only supposed to lock the outer V shaped piece? Obviously it can't be driven down to lock both pieces as the V shaped notches don't line up. But, if I can't drive that outer roll pin in all the way, it doesn't fit in that tube that goes in the housing around it. I'm having a hard time explaining it the way I want to, and I hope you understand what I mean here. I'm very grateful with your previous answers you gave me as to lining up the spools with the ports and such. Maybe I'm just dense, but I'm having a heck of a time figuring out these 2 small roll pins and 2 V grooves. Thanks again
Ross
Ross
