My 706 has 3 of the specified studs with nuts on each hub, no washer at all. The other is a regular 7/8-14 hex head bolt, no washer. While changing tires, I realize the hub is loose.
Looking on CaseIH parts diagram, it appears all 4 are to be the studs with a washer and a nut.
My question - is that some type of special washer? And could I replace the studs with a hex head bolt and lock washer?
Any advice is appreciated
