farmall c 12 volt lights
I bought some rectangular lights for my 400. Mounted them on the light bar. You can pick and chose any thing you want. If you are looking for bulbs to fit the light fixture, take the old bulb into your auto parts store and buy a 12 volt bulb that that has the same base as your old 6 volt bulb.
SDE
If your C has the OEM lights, a #1156 stop/turn/backup bulb is a direct 12 volt replacement.
If you have the lights with the twist-in bulbs, these would work.
https://www.superbrightleds.com/moreinfo/tail-brake-turn/1156-led-bulb-27-smd-led-tower-ba15s-retrofit/2622/
If you have the OEM lights, [b:b54e9c0309]1143[/b:b54e9c0309] is the correct 12 volt bulb. 1156 will work.
AG
Polish the reflectors with chrome polish and clean glass lens and get the LED replacement for 1156 bulb.
