Graveyard1984
I have an h farmall that is currently a tricycle front end and has 3 point hitch.
I've got a wide front end for the h laying in my yard.
I use this tractor for pulling a small Bush hog, pallet forks,moving hay around and etc....
I've owned several tricycle front end tractors and never had any trouble with the tricycle front end.
When I spear a 4x5 roll of hay it gets light in the front.
I've thought about building a weight bracket and hang suit case weights on the nose.
Or I could install the wide front end and it already has a weight bracket mounted on it.
I know wide front is more stable
But a tricycle front end turns better.
What would you guys do in this situation?
Thanks for the input
