Rick Remmert
I went to install my changed over to 12v starter yesterday. I got it all hooked up and went to hook the - cable up. I had sparks everywhere. I took it back off and everything looked fine. I thought maybe I got the + up against the frame. I put it back on, hooked up the - cable and touched the + to the starter switch. Everything was fine. Unhooked the - cable hooked the + back up and went to hook the - back up and sparks again. I took it off and got my ohms meter out. It checked out fine. For some reason I put the hold down nut back on and tightened it down. It had a dead short in it. It was also brand new. I had a spare one, put it on and it worked fine. I guess you should never trust new stuff.
