300U TA question
Charlie M
TA on my 300U is just about out of being able to adjust.It works fine in both low and high range, just no adjustment on the lever left. Does that mean it needs a new TA clutch? I've never been into anything on
the tractor past the engine so getting into a TA is new for me.
Im not familiar with this set up; however "zeketheantiquefreak" has an excellent video of this problem on "Utube"...and there are other videos.....good luck.
Really not sure as to what your sayen here , But heres my take on this , over time ware on the Pin's and the clevis eye's will eat up a lot of adjustment to remove slop , just by replacing wore out pins will gain some back , rebuilding holes or making up bushing and pressing them in to sloppy holes and reaming them to fit NICE on the new pin helps evey couple thousants make a big difference . Just stop and do a wiggle and jiggle test and see what is sloppy , might surprise ya how much FIELD TESTING your tractor went thru over the years.
