W-30 carb- float setting.....
banjoman09
I think it looks fine? Could be a bit lower but the only way I know to change level is by length of needle....I used the one in
the kit so it should be ok... the tab on the side of the float only keeps float from going down too far. Thanks.
you take main jet out and gas should be approx. center of hole when adjusted properly, if the fuel level is too high you have to bend the float carefully to change height
as i said to change float level u bend the arms with needle nose pliars., but it looks not bad as is. the arms need to be level and hard to see in this pic. if anything a bit higher, dont forget it is upside down now!
thought u said u just put a kit in it? that gasket is toast. better make another one. have u checked where the leak is?
yes I did just kit -it..... 3 months ago when I got the dang thing running- then dismantled the tractor- it was leaking then . The gasket will work. I bent it a tad.....all is clean - tank also...Ill see what happens. Thanks
