international 340
gsgs
looking for this fuel part, bottom right.
not sure of name?
As the other guy says sediment bowl assembly common part on most any tractor
eaither i can get new or parts only the glass is broken and i would replace it.
ty for the name did not know it.
There is also a fine mesh screen that's goes just above the sediment bowl gasket. You will want to check it. If its clean then leave it lone. If your lucky you can just replace the bowl. Just make sure when you put the bowl in turn the bowl a little as your tightening up the threaded piece on the bottom. That will insure the glass bowl will line up properly to help seat your gasket.
O'Reilly's auto parts store number is 398 fuel sediment bowl gasket. There are 2 different screen for them depending on if it has the side or center hole but both can also be had from them
You can get the whole assembly from this site, Napa, local tractor dealers who sell parts, heck even my local Tractor Supply sells
them. Some even may have the parts. Not knocking Old, but that number isnt good at my local o'reallys. Even showed them a pic old
posted once of it, they couldnt find the number. But like he once said, hes got his guys trained good, LOL!!
