Fast Hitch Sickle Question
Bryce Frazier
Found a really nice fast hitch mower, however the guy swears up and down it is off of a super a, however he is telling me it has 2 prongs / FH Points?? I was pretty sure A and 100's had a single prong? I was hoping it would fit on my super c?
100, 130, should have single prong. Super C, 200, 230, and I think 240 should use the double small prongs. 300 and larger tractors should use double large prongs.
All 2-point hitches had the same prong spacing. There were 2 different vertical dimensions of the prongs. Are you sure the mower is Fast-Hitch? Maybe the 2 prongs the guy is describing are the 2 ends of the conventional mower drawbar. There were other differences to the 2-point mowers depending on what tractor they fit. A picture would tell a whole lot.
As Jim mentioned above me, the width of the double prong implements are the same. For small vs. are prongs, you can even use shims to make small points fit in the larger tractors.
Well.... It actually ended up being a MasseyFerguson 3 point sickle mower, that someone spent a LOT of time trying to put a 'fast hitch' set up on to it!! Mower is in fairly decent shape none the less, but I didn't but it. Guy wants $125 for it, I think that is fair, but I don't need it really. Have a NICE JD No.5 that goes on the Super A, Ferguson 30, and Farmall H with no issues.
