1066pto losing pressure
Jamie1300
New User
Hi, our 1066 had its pto clutch replaced a couple years back and we have had issues with it running recently (losing pressure) to the point where it actually stops. We have had it tested by a ihc tech to confirm the pressure loss. Now I've had another tech mention replacing the filter that could be gummed up causing a flow issue. Anything else I should be considering before sending it in to get checked out
ASSSUMING the rear end is full of oil, it sounds as if the oil pickup tube may be loose, bent, damaged, or not sealing/sucking air.
That was 2yrs a go pull out the pto and go though it You might
have bad to have teflons pressure lost Through them
Did they just put clutch pack in it when I did that or did they
put the Pistonl rings and the Teflon?s in the O-rings on the
brakes I just want to know if they just call it and just put clutch
packs is there?s a reason why it went out the first timeAnd they
might?ve cut something to when they did that who knows what
they did without turn it back apart you might think it might be a
bunch in the suck tube If it?s been slipping that is not good for
it
