carburetor international 340 tractor
gsgs
does anyone know where to buy this carburetor?
[/img]
Why not rebuild it?? I've rebuilt one that look that bad and worse. Or as said good chance this site has them
Yep carbs are not cheap by any means. You can buy a basic kit from some place like O'Reilly's auto parts for around $2o. Then a good soaking in a good carb cleaner and spraying out with a can of carb cleaner spray and a good poking out of the passage ways wit ha small wire or as I use a torch tip cleaning tool and air goes a long way to fixing one. You may also need to use a Dermil tool to clean it up some also
I'm with old on this one just a run of the mill Marvel Schebler TSX carb-- just did one last week with a kit off of EBAY $27.00, works perfect. Just take the time to clean it spotless inside.
