Connecting rod bolt
I?m kind of going with the vet?s question of what is wrong with that the originals. These engine turn slow and produce low power, rod bolts in them are 99.5% failure free. Small block Chevys built to put out 7-800hp at 7000 rpm use the same size bolts. But if you insist CaseIH online parts shows the bolt and nut for $1.69 ea. See link, no guarantee they are available from IH or if that price is correct. And if you really want to go all out Farmalxl partsx .com shows some for $95.86 each. And they specify it is only the bolt, no nut and the price is for one???
Super C online IH parts
Bolts were damaged by previous owner to the point I cannot get a correct torque reading. Last week 1 bolt and nut combination ordered from Case-IH was $50.00.
Will check out the Chevy rod bolts.
Thank you
