Dual speed pto valve removal
cjrpr
How do you remove the valve that
engages/disengaged on a dual speed pto? I
have the adjuster nut and the nut off that
has the lip seal in it and the valve will
not pull out? It's off a 1486.
At the bottom where that valve is there is a plug takes one inch to take it off or socket it will come out of there And it will drop out maybe into two pieces and oil will come out
