300 Utility Exhaust Manifold
I have a cracked exhaust manifold on my 300 utility and I cant find a replacement. Does anyone know what farmall had the same engine, so that I could maybe find and old m or h to take one off from. If I could do that, of course it would exhaust up instead of down but I think I can work with that.
Should be same as 300 Farmall, possibly same as H, other than they are vertical exaust. I don't know if an industrial version of this engine was made or not butthat would also be a possibility
H SH 300 350 W4 SW4 300U 350U are all interchangeable. The H manifold and W4 manifold may have smaller ports? Jim
If you are getting one from a H make sure 300 carburetor will fit it.
Think carb mounting bolts were farther apart on SH,300 and 350.
