IH584 and M wheel weights
old
So since I had a set of M wheel weights laying around I figured I would see if they would fit on my burnt 584. While they do not fit 100% correctly I did make them fit.
So how much does a set of rear wheel, wheel weights weight?? I had to use 1/2 inch bolts and the 4 on each sit at an angle but there on there so that should help at least a little bit
I use what I have and I do not have any weights from the tractor you listed on hand
If you do happen to come across some Utility weights, you need to be careful because there are a few different ones and they are all just different enough to be annoying.
Make sure you have the right ones before plunking down any money.
The ones for the 24", 26" and 34" pressed steel centers all have different bolt patterns for sure.
While not the best fit using the 1/2 inch bolts lets them sit at an angle in such a way they fit on and are nice and tight. Ya it I wanted to remove the wheel center plate from the axle hub they would have to come off but I have them on
This IH584 has 30 inch rear tires. What is real sad is I picked up A very good used 30 inch rear tire in the correct size for it but it has a gash in the tread area that is about a foot long. Been trying to figure out some way to patch the gash but so far have not come up with a way that I think would work
We just redrilled the holes to fit our steel plate on our 574 we put an old allis weight on the inside then an IH weight on the outside and makes it about flush with the outside of the tire/rim. We have about 300 on the inside of the plate with the others on the outside and loaded tires. Then we have an old gear out of a press on a bale lift for the 3 pt. That is only used if we want extra rear weight. With about 2400 pounds total loaded tires and iron it does pretty good most of the time.
