Transmisson leak
DWHEELS
New User
I have a utility 300 with a T/A, I have a transmission leak towards the front of the transmission. I've tried to find the plate where the leak is coming from but it doesn't show the plate. It's right where the support arms from the front end is bolted to, right behind that there is a plate, is it where there might be a gasket that might be bad or is there a seal that might be bad. hope someone can help. And again I want to thank Jim with my lube problem. Thank you.
The seals above that plate could be TA/transmission, or Engine rear main seal. Use a piece of printer paper and catch a drop. Put
a drop of engine oil from the dip stick next to it. If identical, it is the rear main. if different, it is TA or trans seal.
Either require splitting to fix. Jim
thanks Jim ,I believe it's T/A related as the engine oil has never been down, but the trans has especially when things get warmed up after I've been brush hogging. when I stop and the trans is warm the oil runs right out until it cools down. Again Thank you. Doesn't sound like an easy fix.
Take the cover off,and look up inside towards the rear.The clutch is towards the front.You may be able to see where the fluid is leaking down from.And it may be too messy to tell.Mark
(quoted from post at 13:56:28 10/21/17) Take the cover off,and look up inside towards the rear.The clutch is towards the front.You may be able to see where the fluid is leaking down from.And it may be too messy to tell.Mark
hanks Mark I will try that, it leaks after running for a while when it gets warmed up it leaks really bad, after I park there's a good stream. again thanks, Don.
