Trying to get some help on my farmall H. Have read through pretty much all the post I can find regarding this but I’m just not too certain what is going on. When I bought it I was told it had a bad battery so I replaced it. It ran well for several months but the gauge never really showed that it was charging. So I went through and replaced all the wiring replaced the gauge and pretty much the same. When I pull the ignition switch before starting it the needle on the gauge will vary slightly tip to the discharge side and once I start it it goes back to zero. But it will never charge while running it. It never stalls out but for the first time since I got it it would not start up again after I turned it off until I jumpstarted it. I ran through that checklist that John had posted on here but I’m still kind of confused. If I measure the voltage off the bat terminal of the generator it reads 7.2 V. But if I check voltage on the battery it’s only ever 6.11 V. I’ve gone through checked all my connections and I ran a ground wire from the four. Switch just to make sure it was getting a good ground. Does anybody have any suggestions on what to try? It appears to me that the generator is trying to charge but it’s never getting to the battery.
