I am attempting to use my rear blade to do some grading around my barn. My fast hitch has been converted to have the 3 point top link and have a couple different pairs of the 3 point to fast hitch adapters. Is it possible to get down pressure on the blade? I have the operator manual and have it set up in the 'rigid' hitch position. whenever I lower the blade, it just drags along the top of the ground. If I lower the lift arms, the front of the blade rolls forward. I've tried to adjust the top link in order for it to dig into the ground..but, was unsuccessful. One thing to note is that the 3 point adapter bolted on the tractor for the top link has an upper and lower position. I currently am using the upper position. I was hoping to adjust the adjustable lift links to create the correct slope and grade the ground. Any advice or instructions would greatly be appreciated
One more semi related question..: I have the telescopic drawbar and am unable to slide it into the storage position. Looks like mud is jammed way back into the pocket. Is this pocket open up front for dirt to get in? What is a good way to bust it out?
