I just did some engine work on a friends 350U. After a test drive a noticed oil on the ground from backing it back from not the barn.
There's two drip holes between the trans and torque. I can't tell from the IT manual, is there a "dry" compartment between the trans and torque?
I want to remove the bottom plate to get an idea of where the oil is coming from but wanted some idea of what to expect.
Also, does the hyd have its own reservoir or does it use the transmission?
Thanks
Thanks
