Need some pointers
Wyokid
Changing the front tire on my H. Single front tire, 7.5 x 10. Got the bead broken now to take tire off. The rim is not a drop shoulder like other rims so no place for the bead to drop into. Anyone have any tips on taking the tire off the rim??
Thanks for any help.
Actually answered my own question. Took the 4 bolts out and the rim splits into 2 pieces, so doesn't appear too bad other than manhandling the rim pieces.Now just need to find wheel bearings which may be the more daunting task.
I think it is a bushing, Having one made from an oilite bushing blank, abnd drilling for grease should be 50.00 or so. Jim
You're right Jim, it is a bronze bushing- one in each rim half. Found an old diagram on the web and got a part number. found a dealer who had them, hopefully the diagram was correct and they'll work, other wise will do the drilled bushing thing.
