H Governor Rebuild
FBH44
I have a spare used H governor. Thought I might as well rebuild it. On this site I can find a Governor Spring, and a Throttle Shaft Rebuild Kit. What else might I get to rebuild it? When I take the cover off I do not know if it's pristine condition or worn out. Thanks.
The pins that hold the flyweights, and also the holes in the flyweights get worn out. You can bore out the holes, and install larger pins. Also, the shaft that all of that rides on can become worn. You can take it all apart and polish the worn spots to make it all smooth again. You can make it better than it was, but without replacing some of those parts it will never be as good as new.
