Oil in pulley assembly
that is supposed to get oil from transmission. When changing transmission oil it is recommended to put some in the plug on the top just to make sure it has oil to start with
(quoted from post at 20:43:54 10/18/17) that is supposed to get oil from transmission. When changing transmission oil it is recommended to put some in the plug on the top just to make sure it has oil to start with
Oh ok, is it a good idea to run the pulley every once in awhile to keep the gears lubricated fully or is that not necessary?
