IH 300 Oil Leak from Tach Cable
Illini89
New User
I have an IH 300 Utility that we just acquired. I think this tractor has sat outside for many years. We got it running and now there is oil leaking from the tach cable. Does anyone know what would cause this and if there is an easy fix?
Thanks in advance for all your help.
Do you have any idea if this is available or what the size of the O ring is? We tried to get the tach housing out of the distributor drive housing with no luck. Is there a secret to getting that out?
Thanks again.
In addition to the Oring, the seal on the Hydraulic pump could be failing allowing hydraulic oil to bypass the distributor end
shaft. Jim
