C200 engine
I'm not for sure Phil, but if you are doing a swap of some sort, I believe a C200 from a 674 or the like, has a different rear plate than one from a 544. Something to look into anyway
I'm not doing a swap, I just have a good C200 that I removed from a 544 with a bad hydro. Looking to sell it and want to have an idea what it will fit.
Front cover and rear cover and flywheel and intake and exhaust manifold 574-674 has fuel pump water pump and front damper is all different you mite look for a long block
My understanding is that the C200 for a 574/674 is a completely different engine from the C200 out of a 544.
The C200 from a 544 is basically the C301 6-cylidner with two of the cylinders removed. Front and rear it is identical in mounting to that 221/263/291/301 block.
On a 574/674, the block is the frame, where on the 544 Utility, the tractor has frame rails like the row crop version.
544 Utility:
574 Utility:
