1066 blowing oil and water out the radiator cap
I havent started the 1066 this year and went to start it and of cource it fired right up and started blowing water and oil out the radiator cap isnt this the oil cooler is damaged on the inside or something else? Thanks
I vote the electrolysis. The oil cooler will just push oil into the rad not blow it all over. The electrolysis is the compression will blow it all over like that.
If the oil coming out is black it is the cooler. If it is frothy then it is cavitation erosion of sleeve.
If it's electrolysis it goes into the Pan there's no way it get in the radiator electrolysis will go though through the sleeves to the pan you have oil pressure pushing it to the cooling system and I was talking about sludge
