IH 424 Gas - Air Cleaner Missing, Need Info
RTR
I am currently refurbishing and an IH 424 Tractor. The air cleaner assembly was totally missing when I got the tractor and I need to find one for it. Can any of you help me with pictures and location of what the assembly Looks like and where it's located ? Also, if the assembly is the Siam as other model tractors please let me know. I have parts tractors such as a 140, H, M, and C Tractor's. If the assembly on one of those he is the same that would help out a lot.
I would like to reiterate that this is a gas powered tractor with A C-146 engine. I have a 424 with the diesel engine and that is totally different
I just looked there and it looks as if the 424 gas tractor has a horizontal dry type element filter assembly. I will pretty much need every part associated with that unit as shown in the parts diagram. I'm gonna need to find a parts tractor it looks like.
Let me know if any of you have one or know of a parts tractor it can be removed from. I've called salvage yards here in Alabama and haven't found one yet.
THANKS!
A NAPA or other auto parts store should be able to fix you up with a dry type filter that installs directly in the carburetor. No way I would even consider that as a replacement for the original, but it would allow you to use the tractor.
(quoted from post at 20:49:18 10/16/17)
Yeah I've thought of that but when bush hogging it wouldn't be the best thing to have. I'm trying to get the original. Just have to find a parts tractor.
Personally I think an airbox/paper element air cleaner off anything with equivalent HP is going to be fine, in order to use the tractor. Obviously not show quality without the original setup, but there's a reason oil bath air cleaners aren't used any more.
My opinion as to why...2 reasons...the oil which is pulled over, even in incrementally small amounts, destroys octane & fuel quality...I also believe the paper element filter can take out finer particles.
I converted my Super A over to a Donaldson paper element filter some years back and it is running just fine.
