My 100 I bought this year has a ton of travel on the brake pedals. I can't find my I & T book with the 100 in it but my book for an A says 1 inch of travel on the pedal. I'm assuming the 100 is the same and mine has about 4 inches of travel. The pedals are at the end of their possible travel but I do have enough brake to stop. My question is will it be possible to adjust out the slop or are the brakes worn enough to need new ones or is it a combination of both. I don't know how much travel is removed with a little adjustment and adjustment is way easier than changing the brakes. The clevis's are currently turned in enough to just have the end of the rod coming out of the threaded hole. If its worth an adjustment I'm planning on giving it a try this year but if it needs brakes that's a job for next year. The pins are stuck in the clevis's so what ever I do is going to require some heat.
