So I do not have all the hyd leaks found and fixed but I did use it today. Moved a bit of gravel on my drive way. Did find out that with out any thing on the 3 point it would spin pretty easy but I expected that. Did finally get some hyd fluid flowing out of the pipe that is suppose to go the brake reservoir and I do not know if this will work or not but for now I hook a hose from the pipe to one of the brake master cylinders. Still has a leak below the steering wheel and one at the power steering cylinder but the one at the steering cylinder seems to come and go. I did pretty good other then the leaks. While the loader bucket is about the same as the one on my Ford 841S is seem to have enough more power to fill the bucket before it spins out even with out something on the 3 point. I did put a 6 foot disk on the 3 point plus a wheel weight and a heavy bolt on hub for a B on the disk so it should be a good bit of weight which I think will help. Got dark before I could try it with the disk on
