TractorLinks.com
Show Parts for Model:
W-30 rear tires ?
banjoman09
10-12-2017 08:43:59
Just noticed my W-30 has a 16.9 x 28 on one side; and a 14 x 28 on the other; can you tell me which is right? Thanks.
D beatty
10-12-2017 23:12:09
 Re: W-30 rear tires ? in reply to banjoman09, 10-12-2017 08:43:59
The W stood for standard four wheel tractor.
Jim Becker
10-12-2017 21:48:50
The "W" stands for "wheel".
rustred
10-13-2017 19:31:23
 Re: W-30 rear tires ? in reply to Jim Becker, 10-12-2017 21:48:50
yes, W is for wheeled tractor... and T is for track tractor. example as in WD9 OR TD9.
D beatty
10-14-2017 01:20:43
 Re: W-30 rear tires ? in reply to rustred, 10-13-2017 19:31:23
The W on the W30 through the W9 tractors stood for the standard series tractors of Mc-cormick Deering.
old
10-12-2017 09:39:25
The tire that is a 14X28 is the old tire number system and the 16.9X28 is the new number system. Both are In fact the same size tire. I ran into the same thing this summer on my Oliver S88 and it had a bad 14X38 on it and the new tire I replaced it with is a 16.9X38 because back years ago they changed the way tires where numbered
D beatty
10-12-2017 22:53:51
 Re: W-30 rear tires ? in reply to old, 10-12-2017 09:39:25
There is a difference between the 14x28 and the 16.9x28. The 16.9x28 inch put 30 square inches more rubber on ground over 14x28's. It's the same with your 14x38's verses 16.9x38's. The 16.9x38's put 52 square inches more rubber on the ground over the 14x38's.
oliverdiesellover
10-14-2017 17:18:48
 Re: W-30 rear tires ? in reply to D beatty, 10-12-2017 22:53:51
They are the same size. The 14-38 in today's chart are actually 15.5-38. That is why they show different footprints.
D beatty
10-14-2017 19:53:15
 Re: W-30 rear tires ? in reply to oliverdiesellover, 10-14-2017 17:18:48
There is a pullers chart that tells the square inches of rubber on ground for the different sizes and the 16.9x38 puts more square inches of rubber on the ground than a a 14x38 tire.
oliverdiesellover
10-15-2017 07:59:52
 Re: W-30 rear tires ? in reply to D beatty, 10-14-2017 19:53:15
So let me guess it shows a 14x38 around 200 sq in. And a 16.9 around 250.
D beatty
10-15-2017 09:22:36
 Re: W-30 rear tires ? in reply to oliverdiesellover, 10-15-2017 07:59:52
There are several charts out there on how many square inches of rubber is put on ground. Firestones chart is different than the NTPA chart but Firestone bases theirs on running on plowed gruond and NTPA bases theirs on a hard clay track. A 14.x38 rear tractor tire has a larger square inch foot print than a 15.5x38. The 15.5x38 is actually small in diameter than a the 14.9x38.
banjoman09
10-12-2017 10:12:30
Makes sense..... they both look about the same- wasnt sure...thanks to you both!
old
10-12-2017 11:21:49
 Re: W-30 rear tires ? in reply to banjoman09, 10-12-2017 10:12:30
You know me I am always happy to help if and when I can. I saw who posted this and figured I would at least look at your post. If you had asked about the tractor it self I would not have answered your post LOL
banjoman09
10-12-2017 12:31:21
 Re: W-30 rear tires ? in reply to old, 10-12-2017 11:21:49
Hey - dont be that way! I thought we were "good" ? I will try not to use "restore" anymore...better? Thanks.
old
10-12-2017 14:56:31
 Re: W-30 rear tires ? in reply to banjoman09, 10-12-2017 12:31:21
Well in this area we almost never see a W-30 so it is a tractor that I know very little of since I do not even remember seeing one even at a show
banjoman09
10-12-2017 19:20:33
 Re: W-30 rear tires ? in reply to old, 10-12-2017 14:56:31
just saw this- ok- that must mean there not a "collectable"...darn it.
old
10-12-2017 20:55:03
 Re: W-30 rear tires ? in reply to banjoman09, 10-12-2017 19:20:33
I did not say that. From what I understand and I could be wrong the W stands for Wheatland and well where I live there is no wheat land. I still remember when I lived in Winfield KS there was a lot of wheat fields and a Wheatland tractor would have been common in that area
Jim Becker
10-12-2017 08:57:03
Both.
http://www.millertire.com/faqs/
